用XXXXXT(代码翻自C#) 实现动态编译
novakon2012/08/31软件综合 IP:广东
动态编译可以理解为,程序在执行过程中编译一段代码并把编译之后的结果作为程序的一部分运行。
效果:
如果你对VB语法有了解,可以尝试修改代码,并观察输出的结果。
编译好的程序在RTC\bin\release 文件夹下,可以直接运行。
源代码附在zip包里。注释是英文写的,英文不好的兄弟我向您道个歉
代码已经非常简洁了 。如果您没有Visual Studio 11(我用的版本),可以在VS2010 VS2008或者其他.NET环境下创建项目并复制窗体和代码。
attachment icon RTC.zip 72.85KB ZIP 16次下载
来自:计算机科学 / 软件综合
novakon 作者
12年4个月前 IP:未同步
446873
源码
REM Dynamic Compilation Demo in VB
REM translated from the C# code found on Internet.
REM by Qin Yongliang, 20120831
REM feel free to use the code for any purpose
Imports XXXXXXXXXXXXXXXXXXpiler
Imports XXXXXXXXXXXXsualBasic
Imports Microsoft.CSharp
'optional.
Imports XXXXXXXXXflection
Public Class Form1
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles XXXXXXXXXXick
        Button1.Text = "Compiling..."
        Me.Enabled = False
        XXXXXfresh()
        Dim cpara = New CompilerParameters
        XXXXXXXXXpilerOptions = Trim(TextBox2.Text)
        'options like "/optimize" or whatever
        XXXXXXXXnerateInMemory = True
        'stores the compile result in memory.
        XXXXXXXXcludeDebugInformation = False 'we are unlikely to debug it
        'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXd("mscorlib.dll")
        'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXd("system.dll")
        'add references if needed.
        Dim cdp = XXXXXXXXXXXXXXXXXXeateProvider("VisualBasic")
        'self-explaining
        Dim res = XXXXXXXpileAssemblyFromSource(cpara, TextBox1.Text) 'show results
        'MsgBox(XXXXXXrors(0).ToString)
        'check if errors occur.
        Dim asm = XXXXXXXpiledAssembly 'as XXXXXXXXXXXXXXXXXXXXsembly
        Dim newclass = XXXXXXeateInstance("newclass") 'create instance from compiled assembly
        Dim newclasstype = XXXXXXXXXXXtType
        Button1.Text = "Running..."
        Dim ret As Double = XXXXXXXXXXXXXXXtMethod("test").Invoke(newclass, Nothing)
        'assume the code returns a number; assume the code has no parameters("Nothing");
        Button1.Text = "Finished!"
        MsgBox(XXXXXXString, , "Result of test()") 'show result of the invoked method
        Button1.Text = "Compile and Run"
        Me.Enabled = True
    End Sub
End Class
novakon
2008/03/29注册,2年10个月前活动
已走,勿送
