今天上Software Design课无聊于是上起4HV(没被学校Block掉),突然看见一张凶残的ZVS
这仅仅增加了两个绕组和两个电阻就能达到性能提高35%的效果么[s:225]
求各位鉴定
There is a revision of the ZVS by Andrinerii, He adds 2 separate 3 turn coils on top of the existing 10 turn primary, each with a series 100 Ohm resistor. This circuit supposedly adds a 35% increase in performance. Important: Make sure your 3 turn winds are the same direction as the primary, otherwise your driver will be dead!
http://wiki.4hv.org/index.php/Flyback
