一个简单的WIN32程序;
平台VC++ 6.0
干掉360老的版本是可以的
//线程参数结构体定义
typedef struct _RemoteParam
char szMsg[12]; //MessageBox函数中显示的字符提示
DWORD dwMessageBox;//MessageBox函数的入口地址
} RemoteParam, * PRemoteParam;
//定义MessageBox类型的函数指针
typedef int (__stdcall * PFN_MESSAGEBOX)(HWND, LPCTSTR, LPCTSTR, DWORD);
//线程函数定义
DWORD __stdcall threadProc(LPVOID lParam)
RemoteParam* pRP = (RemoteParam*)lParam;
PFN_MESSAGEBOX pfnMessageBox;
pfnMessageBox = (PFN_MESSAGEBOX)pRP->dwMessageBox;
pfnMessageBox(NULL, pRP->szMsg, pRP->szMsg, 0);
return 0;
//提升进程访问权限
bool enableDebugPriv()
HANDLE hToken;
LUID sedebugnameValue;
TOKEN_PRIVILEGES tkp;
if (!OpenProcessToken(GetCurrentProcess(), TOKEN_ADJUST_PRIVILEGES | TOKEN_QUERY, &hToken))
return false;
if (!LookupPrivilegeValue(NULL, SE_DEBUG_NAME, &sedebugnameValue))
CloseHandle(hToken);
return false;
tkp.PrivilegeCount = 1; tkp.Privileges[0].Luid = sedebugnameValue; tkp.Privileges[0].Attributes = SE_PRIVILEGE_ENABLED; if (!AdjustTokenPrivileges(hToken, FALSE, &tkp, sizeof(tkp), NULL, NULL))
return false;
return true;
//根据进程名称得到进程ID,如果有多个运行实例的话,返回第一个枚举到的进程的ID
DWORD processNameToId(LPCTSTR lpszProcessName)
HANDLE hSnapshot = CreateToolhelp32Snapshot(TH32CS_SNAPPROCESS, 0);
PROCESSENTRY32 pe;
pe.dwSize = sizeof(PROCESSENTRY32);
if (!Process32First(hSnapshot, &pe))
return 0;
while (Process32Next(hSnapshot, &pe))
if (!StrCmpI(lpszProcessName, pe.szExeFile)) {
return pe.th32ProcessID; }
return 0;
int main(int argc, char* argv[])
//定义线程体的大小
const DWORD dwThreadSize = 4096;
DWORD dwWriteBytes;
//提升进程访问权限
enableDebugPriv();
//等待输入进程名称,注意大小写匹配
std::cout << "[s:9]lease input the name of target process !" << std::endl;
char szExeName[MAX_PATH] = { 0 };
std::cin >> szExeName;
DWORD dwProcessId = processNameToId(szExeName);
if (dwProcessId == 0)
MessageBox(NULL, "The target process have not been found !", "Notice", MB_ICONINFORMATION | MB_OK);
return -1;
//根据进程ID得到进程句柄
HANDLE hTargetProcess = OpenProcess(PROCESS_ALL_ACCESS, FALSE, dwProcessId);
if (!hTargetProcess)
MessageBox(NULL, "Open target process failed !", "Notice", MB_ICONINFORMATION | MB_OK);
return 0;
//在宿主进程中为线程体开辟一块存储区域
//在这里需要注意MEM_COMMIT | MEM_RESERVE内存非配类型以及PAGE_EXECUTE_READWRITE内存保护类型
//其具体含义请参考MSDN中关于VirtualAllocEx函数的说明。
void* pRemoteThread = VirtualAllocEx(hTargetProcess, 0, dwThreadSize, MEM_COMMIT | MEM_RESERVE, \
PAGE_EXECUTE_READWRITE);
if (!pRemoteThread)
MessageBox(NULL, "Alloc memory in target process failed !", "notice", MB_ICONINFORMATION | MB_OK);
return 0;
//将线程体拷贝到宿主进程中
if (!WriteProcessMemory(hTargetProcess, pRemoteThread, &threadProc, dwThreadSize, 0))
MessageBox(NULL, "Write data to target process failed !", "Notice", MB_ICONINFORMATION | MB_OK);
return 0;
//定义线程参数结构体变量
RemoteParam remoteData;
ZeroMemory(&remoteData, sizeof(RemoteParam));
//填充结构体变量中的成员
HINSTANCE hUser32 = LoadLibrary("User32.dll");
remoteData.dwMessageBox = (DWORD)GetProcAddress(hUser32, "MessageBoxA");
strcat(remoteData.szMsg, "Hello\0"); //为线程参数在宿主进程中开辟存储区域
RemoteParam* pRemoteParam = (RemoteParam *)VirtualAllocEx(hTargetProcess , 0, sizeof(RemoteParam), \
MEM_COMMIT, PAGE_READWRITE);
if (!pRemoteParam)
MessageBox(NULL, "Alloc memory failed !", "Notice", MB_ICONINFORMATION | MB_OK);
return 0;
//将线程参数拷贝到宿主进程地址空间中
if (!WriteProcessMemory(hTargetProcess, pRemoteParam, &remoteData, sizeof(remoteData), 0))
return 0;
//在宿主进程中创建线程
HANDLE hRemoteThread = CreateRemoteThread(hTargetProcess, NULL, 0, \
(DWORD (__stdcall *)(void *))pRemoteThread, pRemoteParam, 0, &dwWriteBytes);
if (!hRemoteThread)
MessageBox(NULL, "Create remote thread failed !", "Notice", MB_ICONINFORMATION | MB_OK);
return 0;
if (hRemoteThread)
::WaitForSingleObject(hRemoteThread, INFINITE);
::CloseHandle(hRemoteThread);
::VirtualFreeEx(hTargetProcess, pRemoteThread, dwThreadSize, MEM_RELEASE);
::VirtualFreeEx(hTargetProcess, pRemoteParam, sizeof(remoteData), MEM_RELEASE);
::CloseHandle(hTargetProcess);
return 0;
CreateRemoteThread.rar
9.01KB
RAR
23次下载
