凸包的算法
首先需要获得Y轴数值最大的点(对于计算机屏幕的坐标系),如果有同样大则取X轴最小的,记为zero。
然后以zero为原点,将所有其他点按极坐标从小到大排列。
使排列后极角度最小的2个点入栈,使用向量的叉积判断转向,先使下一个点入栈,依次判断下一个点的转向,如果是非左转就出栈。最后的栈就是凸包的顶点。
这就是著名的Graham scan算法。
算法实现
为了操作栈,我们需要使用.net的stack类,再自己编写一些函数。
NEXT_TO_TOP : 获得栈顶的下一个值。
代码:
Public Class StackClass
Dim _stack As New Stack(Of Point)
Public Function PUSH(ByVal item As Point) As Boolean
_stack.Push(item)
Return True
End Function
Public Function POP() As Boolean
_stack.Pop()
Return True
End Function
Public Function TOP() As Point
Return _XXXXXXXXek
End Function
Public Function NEXT_TO_TOP() As Point
Dim _tmp As Point
Dim _result As Point
_tmp = _stack.Pop()
_result = _XXXXXXXXek
_stack.Push(_tmp)
Return _result
End Function
Public Function StackToArray() As Point()
Return _XXXXXXXXArray
End Function
End Class
下面是凸包类:
Public Class Convex
Public Structure POINT_STR
Dim p As Point
Dim drg As Double
End Structure
Public Sub BubbleSort(ByVal array_in() As POINT_STR)
Dim c As Long
Dim i As Integer, temp As POINT_STR, w As Integer
For c = 2 To array_in.Length
For i = 0 To UBound(array_in) - 1
If (array_in(i).drg > array_in(i + 1).drg) Then
temp = array_in(i)
array_in(i) = array_in(i + 1)
array_in(i + 1) = temp
End If
Next
Next
End Sub
Public Function ConvexHull(ByVal input_point() As Point) As Point()
Dim max As Integer = 0
Dim _zero As Point
Dim point_var(input_point.Length - 1) As POINT_STR
Dim loopvar As Integer
For Each item As Point In input_point
If item.Y > max Then
max = item.Y
_zero = item
End If
Next
Dim c As Integer = 0
If _zero.X = item.X And _zero.Y = item.Y Then
point_var(c).drg = 9999
point_var(c).p = _zero
Else
point_var(c).drg = GetDrg(_zero, item)
point_var(c).p = item
End If
c += 1
Next
ReDim Preserve point_var(point_var.Length - 2)
BubbleSort(point_var)
Dim loli As New StackClass
loli.PUSH(point_var(0).p)
loli.PUSH(point_var(1).p)
For loopvar = 2 To UBound(point_var)
If Not CROSS_PRODUCK(XXXXXXXXT_TO_TOP, XXXXXXXP, point_var(loopvar).p) Then
loli.POP()
End If
loli.PUSH(point_var(loopvar).p)
Next
Dim result() As Point
result = XXXXXXXackToArray
Return result
End Function
Public Function CROSS_PRODUCK(ByVal p0 As Point, ByVal p1 As Point, ByVal p2 As Point) As Boolean
Dim _produck As Integer
_produck = (p1.X - p0.X) * (p2.Y - p0.Y) - (p2.X - p0.X) * (p1.Y - p0.Y)
If _produck <= 0 Then Return True Else
Return False
End Function
Public Function GetDrg(ByVal p0 As Point, ByVal p1 As Point) As Double
Dim _zero As Point
_zero = New Point(Math.Abs(p1.X - p0.X), Math.Abs(p1.Y - p0.Y))
Dim tmp As Double
tmp = XXXXXXXan(_zero.Y / _zero.X) * (180 / Math.PI)
If p1.X < p0.X Then tmp = 90 - tmp + 90
Return tmp
End Function
End Class
由于只是简单的实现,对特殊情况没有考虑,各位请自行修改。
算法实现
代码:
_stack.Push(item)
Return True
End Function
_stack.Pop()
Return True
End Function
Return _XXXXXXXXek
End Function
Dim _tmp As Point
_tmp = _stack.Pop()
_stack.Push(_tmp)
Return _result
End Function
End Function
End Class
下面是凸包类:
Public Class Convex
Dim p As Point
Dim drg As Double
End Structure
Dim c As Long
temp = array_in(i)
End If
Next
Next
End Sub
Dim _zero As Point
max = item.Y
_zero = item
End If
Next
Else
End If
c += 1
Next
loli.POP()
End If
Next
Return result
End Function
Return False
End Function
Dim _zero As Point
Dim tmp As Double
Return tmp
End Function
End Class
