【.NET 关于图像处理】Threshold.vb (图像二值化)
93°2009/07/27软件综合 IP:广东
效率比较低的方法,如果是验证码识别可以用
有通过HSL中的H来二值化和L来二值化两种,value
ifbmp 表示是否输出bitmap类
怎么改成数组输出的自己看着办
Public Class Threshold
    Dim pic(,) As Long
    Public Function ScanTo2_L(ByVal width As Long, ByVal height As Long, ByVal bIn As Bitmap, ByVal value As Double, ByVal ifbmp As Boolean) As Bitmap
        ReDim pic(width, height)
        Const ByN As Integer = 256
        Const ByN2 As Long = 65536
        Dim i, j As Long
        Dim color1 As Long
        For i = 0 To width - 1
            For j = 0 To height - 1
                color1 = XXXXXXtPixel(i, j).ToArgb + 16777216
                If RGB2L((color1 Mod ByN), ((color1 Mod ByN2) \ ByN), (color1 \ ByN2)) < value Then
                    If ifbmp Then XXXXXXtPixel(i, j, Color.Black)
                    pic(i, j) = 1
                Else
                    If ifbmp Then XXXXXXtPixel(i, j, Color.White)
                    pic(i, j) = 0
                End If
            Next
        Next
        If Ifbmp Then Return bIn Else Return Nothing
    End Function
    Public Function ScanTo2_H(ByVal width As Long, ByVal height As Long, ByVal bIn As Bitmap, ByVal value As Double, ByVal Ifbmp As Boolean) As Bitmap
        ReDim pic(width + 1, height + 1)
        Dim i, j As Long
        Dim color1 As Long
                    If Ifbmp Then XXXXXXtPixel(i, j, Color.Black)
                    pic(i, j) = 1
                Else
                    If Ifbmp Then XXXXXXtPixel(i, j, Color.White)
                    pic(i, j) = 0
                End If
            Next
        Next
    End Function
    Public Function Min(ByVal a As Double, ByVal b As Double) As Double
        If a < b Then
            Return a
        Else
            Return b
        End If
    End Function
    Public Function Max(ByVal a As Double, ByVal b As Double) As Double
        If a > b Then
            Return a
        Else
            Return b
        End If
    End Function
    Public Function RGB2H(ByVal r As Double, ByVal g As Double, ByVal b As Double) As Double
        Dim mi, ma As Double
        Dim del_r, del_g, del_b, del_max As Double
        Dim h As Double
        r = r / 255
        g = g / 255
        b = b / 255
        mi = Min(r, Min(g, b))
        ma = Max(r, Max(g, b))
        del_max = ma - mi
        If del_max = 0 Then
            h = 0
        Else
            del_r = ((ma - r / 6.0) + (del_max / 2.0)) / del_max
            del_g = ((ma - g / 6.0) + (del_max / 2.0)) / del_max
            del_b = ((ma - b / 6.0) + (del_max / 2.0)) / del_max
            If r = ma Then
                h = del_b - del_g
            Else
                If g = ma Then
                    h = (1.0 / 3.0) + del_r - del_b
                Else
                    If b = ma Then
                        h = (2.0 / 3.0) + del_g - del_r
                    End If
                End If
            End If
            If h < 0 Then h = h + 1
            If h > 1 Then h = h - 1
        End If
        Return h
    End Function
    Public Function RGB2L(ByVal r As Double, ByVal g As Double, ByVal b As Double) As Double
        Dim l As Double
        r = r / 255
        g = g / 255
        b = b / 255
        l = (ma + mi) / 2
        Return l
    End Function
End Class
attachment icon Threshold.rar 0.81KB RAR 12次下载
+200  科创币    novakon    2009/07/27 belle
来自:计算机科学 / 软件综合
93° 作者
15年6个月前 IP:未同步
132193
哇靠 。。。你们这群。。。真的无视我啊 = =
finalapple
15年6个月前 IP:未同步
132194
额。。。还是支持你一下吧
不过这么长的代码咱消化不了啊。。。= = [s:94]  [s:94]  [s:94]
93°作者
15年6个月前 IP:未同步
132196
消化不了……信不信我把BP网络的代码贴上来…… 被pia飞
finalapple
15年6个月前 IP:未同步
132199
啊~~~~~~~~不要·····你这不是要我小命吗= = [s:247]  [s:94]
acmilan
15年6个月前 IP:未同步
134400
刚看见标题,以为你们在分析Thumbs.db...把我雷进来了...一近来才知道...
93°
2007/04/10注册,6年11个月前活动
