hello world是一个经典的语句。
ActionScript
trace("Hello, world!");
[1]
Ada
with TEXT_IO;
procedure HELLO
is begin TEXT_IO.
PUT_LINE ("Hello, world!");
end HELLO;
[1]
汇编语言
x86 CPU,GNU/Linux,NASM
section .data msg
db 'Hello, world!',0xA len
equ $-msg
section .text global _start
_start
: mov edx,len
mov ecx,msg
mov ebx,1 mov eax,4 int 0x80 mov ebx,0 mov eax,1 int 0x80
x86 AT&T、Gas
.data
msg : .string "Hello, world!\n"
len = . - msg
.text
.global _start
_start:
movl $len, %edx
movl $msg, %ecx
movl $1 , %ebx
movl $4 , %eax
int $0x80
movl $0 , %ebx
movl $1 , %eax
int $0x80
[1]
x86 CPU、Windows、MASM32
.386 .model
flat,stdcall
option casemap
:none
;========================================================== include windows
.inc include user32
.inc includelib user32
.lib
include kernel32
.inc includelib kernel32
.lib
;========================================================== .data szCaption
db "A MessageBox!", 0 szText
db "Hello, world!", 0 ;========================================================== .code start: invoke MessageBox
, NULL
, addr szText
, addr szCaption
, MB_OK
invoke ExitProcess
, NULL
;========================================================== end
start
8086操作系统(nasm)
[BITS 16] org
0x7c00 mov ax,cs mov ds,ax mov es,ax call DispStr
jmp $;End Hear DispStr
: mov ax, BootMessage
mov bp, ax mov cx, 16;How long is the String mov ax, 0x1301 mov bx, 0x000c mov dl, 0 int 0x10 ret BootMessage
: db "Hello, world!" times 510-($-$$) db 0x0 dw 0xaa55; Bootable Mark
ASP
<% Response.
Write("Hello, world!") %>
[1]
或者简单地写成:
<%= "Hello, world!" %>
AutoIt
MsgBox(1,'','Hello, world!')
AWK
BEGIN { print "Hello, world!" }
[1]
Bash (or sh)
echo 'Hello, world!'
或者:
printf 'Hello, world!\n'
[1]
BASIC
传统版 BASIC(例如 GWBASIC):
10 PRINT "Hello, world!" 20 END
或在提示符输入:
"Hello, world!"
现代版 BASIC(例如 Quick BASIC):
以下的语句,在 Quick BASIC 中同样有效:
"Hello, world!"
BCPL
GET "LIBHDR"
LET START () BE
WRITES ("Hello, world!*N")
Brainfuck
BlitzBasic
Print "Hello, world!" WaitKey
BOO
C
#include <stdio.h> int main
(void) { printf("Hello, world!\n"); return 0; }
或者:
(void) { puts("Hello, world!"); return 0; }
[1]
C++
#include <iostream> int main
() { std
::cout << "Hello, world!" << std
::endl; return 0; }
或者:
#include <iostream> using namespace std
; int main
() { cout << "Hello, world!" << endl
; return 0; }
[1]
C++/CLI
int main
() { System
::Control::WriteLine("Hello, world!"); }
C# (C Sharp)
class HelloWorldApp
{ static void Main
(string[] args
) { System
.Console.WriteLine("Hello, world!"); } }
[1]
或者(仅用于Microsoft Windows)
class HelloWorldApp
{ [DllImport
("user32.dll")] static extern MessageBox
(string title,
string message
); public static void Main
() { MessageBox
(null,
或者(使用附加的Windows Forms)
using XXXXXXXXXXXXXXXXXrms; class HelloWorldApp
{ public static void Main
() { MessageBox
.Show("Hello, world!"); } }
COBOL
IDENTIFICATION DIVISION. PROGRAM-ID. HELLO-WORLD
. ENVIRONMENT DIVISION. DATA DIVISION. PROCEDURE DIVISION. DISPLAY "Hello, world!". STOP RUN.
[1]
Common Lisp
;直接输出 "Hello world!" ;或者 (format t
"Hello world!~%")
[1]
DOS批处理
@echo Hello, world
对于MS-DOS 3.0或更低版本:
echo off
cls
echo Hello, world
Linux Shell
echo Hello, world
[1]
Eiffel
class HELLO_WORLD
creation make
feature make
is local io
:BASIC_IO
do !!io
io.
put_string("%N Hello, world!") end -- make end -- class HELLO_WORLD
[1]
Erlang
-module(hello).
-export([hello_world/0]).
hello_world() -> io:fwrite("Hello, World!\n").
Flowgorithm[编辑]
主条目:Flowgorithm (programming language)
Forth
." Hello, world!" CR
[1]
Fortran
WRITE
*) 'Hello, world!' STOP END
[1]
HTML
Hello World
<html> <head> <title> Hello World
</title> </head> <body> Hello World
</body> </html>
[1]
HQ9+[
H
INTERCAL
PLEASE DO ,1
<- #13
DO ,1 SUB
#1
<- #238
DO ,1 SUB
#2
<- #112
DO ,1 SUB
#3
<- #112
DO ,1 SUB
#4
<- #0
DO ,1 SUB
#5
<- #64
DO ,1 SUB
#6
<- #238
DO ,1 SUB
#7
<- #26
DO ,1 SUB
#8
<- #248
DO ,1 SUB
#9
<- #168
DO ,1 SUB
#10
<- #24
DO ,1 SUB
#11
<- #16
DO ,1 SUB
#12
<- #158
DO ,1 SUB
#13
<- #52
PLEASE READ OUT ,1
PLEASE GIVE UP
[1]
Java
public class Hello
{ public static void main
(String[] args
) { System.
out.
println("Hello, world!"); } }
or in tinystruct2.0:
package tinystruct.examples; import org.tinystruct.AbstractApplication; import org.tinystruct.Application; import org.tinystruct.ApplicationException; import XXXXXXXXXXXXXXXXXstem.ApplicationManager; public class hello
extends AbstractApplication
{ @Override
public void init
() { // TODO Auto-generated method stub this.
setAction("say",
"say"); } @Override
public String version
() { // TODO Auto-generated method stub return null; } public String say
(String words
){ System.
out.
println(words
); return words
* @param args
* @throws ApplicationException
*/ public static void main
(String[] args
) throws ApplicationException { // TODO Auto-generated method stub // Praise to the Lord! ApplicationManager.
install(new hello
()); // to print 'Hello World' ApplicationManager.
call("say/Hello World",
null); // Hello World // or... Application app
=ApplicationManager.
get( hello.
class.
getName()); app.
invoke("say",
new Object[]{"Hello, World!
"}); // Hello, World!
app.
invoke("say",
new Object[]{"Bye!
"}); // Bye!
// or... // http://localhost:8080/?q=say/Hello World // XXXXXXXXXXXXXXXXXX/m0ver/tinystruct2.0 } }
JSP
<% out.
print("Hello, world!"); %>
[1]
或者简单地写成:
<%="Hello, world!"%>
Lisp
;直接输出 "hello, world" ;或者 (format t
"hello, world~%")
Lua
[1]
Malbolge
('&%:9]!~}|z2Vxwv-,POqponl$Hjig%eB@@>}=<M:9wv6WsU2T|nm-,jcL(I&%$#"
`CB]V?Tx<uVtT`Rpo3NlF.Jh++FdbCBA@?]!~|4XzyTT43Qsqq(Lnmkj"Fhg${z@>
Mathematica
Hello[] := Print["
Hello World!"]
Hello[]
[1]
Metapost[
beginfig(1);
draw (0,0)--(0,10);
draw (0,5)--(5,5);
draw (5,0)--(5,10);
draw (12,0)--(7,0)--(7,10)--(12,10);
draw (12,5)--(7,5);
draw (14,10)--(14,0)--(19,0);
draw (21,10)--(21,0)--(26,0);
draw (28,5)...(30.5,0)...(33,5)...(30.5,10)...cycle;
draw (38,10)--(39.25,0)--(40.5,10)--(41.75,0)--(43,10);
draw (45,5)...(47.5,0)...(50,5)...(47.5,10)...cycle;
draw (52,0)--(52,10);
draw (52,10)..(57,4)..(52,6.5);
draw (52,5)--(57,0);
draw (61,10)--(61,0)--(66,0);
draw (68,10)--(68,0)..(73,5)..cycle;
endfig;
end
MIXAL
TERM EQU 19 the MIX console device number
ORIG 1000 start address
START OUT MSG(TERM) output data at address MSG
HLT halt execution
MSG ALF "MIXAL"
ALF " HELL"
ALF "O WOR"
ALF "LD "
END START end of the program
Nuva
<..直接输出..>
Hello, world!
<..或者..>
// 不带换行
? "Hello, world!"
// 或者
// 带换行
?? 'Hello, world!'
Objective-C
#import <Foundation/Foundation.h> int main
(int argc,
const char * argv
[]) { @autoreleasepool
{ NSLog
(@"Hello, World!");
} return 0;
[1]
OCaml
let main
() = print_endline "Hello world!";;
Pascal
program Hello
;{此行可以省略} begin writeln('Hello, world!'); end.
[1]
Perl
#!/usr/bin/env perl print "Hello, world!\n";
Perl 5.10(含)以后版本:
#!/usr/bin/env perl use 5.010; say
"Hello, world!";
[1]
PHP
<?php echo 'Hello, world!';//通常使用這個,比 print 少一個字元 print 'Hello, world!'; ?>
或者
<?= "Hello World!"?>
Pike
#!/usr/local/bin/pike
int main()
write("Hello, world!\n");
return 0;
PL/I
Test: procedure options(main);
declare My_String char(20) varying initialize('Hello, world!');
put skip list(My_String);
end Test;
Prolog
goal
write("hello
,world
Python
适用于Python 2:
#!/usr/bin/env python print "Hello, world!"
适用于Python 3:
#!/usr/bin/env python print(
"Hello, world!")
[1]
REXX
say "Hello, world!"
Ruby
#!/usr/bin/ruby puts "Hello, world!"
[1]
Sbyke Laborana
INIT min:1001
Om:"Hello, world!"
Scheme
(display "Hello, world!") (newline)
Scratch
主条目:Scratch (编程语言)
sed
(需要至少一行输入)
sed -ne '1s/.*/Hello, world!/p'
Seed7
$ include "seed7_05.s7i";
const proc: main is func
begin
writeln("Hello, world!");
end func;
Smalltalk
Transcript show:
'Hello, world!'
Small Basic
TextWindow.WriteLine("Hello, world!")
SNOBOL
OUTPUT = "Hello, world!"
END
SQL
第一种
CREATE TABLE MESSAGE
(TEXT
CHAR(15));
INSERT INTO MESSAGE
(TEXT
) VALUES ('Hello, world!');
SELECT TEXT
FROM MESSAGE;
DROP TABLE MESSAGE;
第二种
SELECT 'hello, world';
第三种
print
'hello,world!'
Swift
println("Hello, World!")
Tcl
#!/usr/local/bin/tcl
TScript
? "Hello, world!"
Turing
put "Hello, world!"
UNIX-style shell
程序中的/bin/sh可改为您使用的shell
#!/bin/sh echo 'Hello, world!'
bc
#!/usr/bin/bc -q
print "Hello World"
quit
dc
#!/usr/bin/env dc
[Hello World]p
Wiki
<includeonly>Hello, World!</includeonly>
GUI
Delphi
program HelloWorld
; uses Dialogs
; begin ShowMessage
('Hello, World!'); end.
Nuva
XXXXXXXXXXXXowMessage('Nuva', 'Hello, world!', ['OK'])
Visual Basic
MsgBox
"Hello, world!" '或者 Print "Hello, world!"
Visual FoxPro
? "Hello, world!"
X11
用一个程序
xmessage 'Hello, world!'
使用Qt
#include <QApplication> #include <QLabel> int main
(int argc,
char *argv
[]) { QApplication app
(argc, argv
); QLabel label
("Hello, world!"); label.
show(); return app.
exec(); }
C 和 GTK+
#include <gtk/gtk.h> int main
(int argc
, char * args
[]) { GtkWidget
* win
, * label
; gtk_init
(& argc
, & args
); label
= gtk_label_new
("Hello, world!"); win
= gtk_window_new
(GTK_WINDOW_TOPLEVEL
); gtk_container_add
(GTK_CONTAINER
(win
), label
); gtk_widget_show_all
(); gtk_main
(); return 0; }
用C++和gtkmm 2
#include <iostream> #include <gtkmm/main.h> #include <gtkmm/button.h> #include <gtkmm/window.h> using namespace std
; class HelloWorld
: public Gtk
::Window { public: HelloWorld
(); virtual ~HelloWorld
(); protected: Gtk
::Button m_button
; virtual void on_button_clicked
(); }; HelloWorld
::HelloWorld() : m_button
("Hello, world!") { set_border_width
(10); m_button.
signal_clicked().
connect(SigC
::slot(*this,
&HelloWorld
::on_button_clicked)); add
(m_button
); m_button.
show(); } HelloWorld
::~HelloWorld
() {} void HelloWorld
::on_button_clicked() { cout << "Hello, world!" << endl
; } int main(
int argc,
char *argv
{ Gtk
::Main kit
(argc, argv
); HelloWorld helloworld
; Gtk
::Main::run(helloworld
Java
import XXXXXXXt.*; import XXXXXXXt.event.*; public class HelloFrame
extends Frame { HelloFrame
(String title
) { super(title
); } public void paint
(Graphics g
) { super.
paint(g
); java.
awt.
Insets ins
= this.
getInsets(); g.
drawString("Hello, World!", ins.
left + 25, ins.
top + 25); } public static void main
(String args
[]) { HelloFrame fr
= new HelloFrame
("Hello"); fr.
addWindowListener( new WindowAdapter() { public void windowClosing
(WindowEvent e
) { System.
exit( 0 ); } } ); fr.
setResizable(true); fr.
setSize(500,
100); fr.
setVisible(true); } }
Java Applet
Java Applet用于HTML文件。
HTML代码:
<html> <head> <title>Hello World
</title> </head> <body> HelloWorld Program says:
<applet code="XXXXXXXXXXXXXass" width="600" height="100"> </applet> </body> </html>
Java代码:
import java.applet.*; import XXXXXXXt.*; public class HelloWorld
extends Applet { public void paint
(Graphics g
) { g.
drawString("Hello, world!",
100,
50); } }
JavaScript
JavaScript是一种脚本语言。最广泛用于HTML文件中,也可以用在其它宿主环境下,比如Microsoft? Windows? 脚本宿主(WSH)和一些web服务环境。
用于HTML中:
alert
("Hello, World!"); //或者 document.
write("Hello, World!");
用于WSH中:
WScript.
Echo("Hello, World!");
PostScript
PostScript是一种专门用来创建图像的语言,常用于打印机。
/font /Courier findfont 24 scalefont
font setfont
100 100 moveto
(Hello World!) show
showpage
XAML
<Page xmlns="XXXXXXXXXXXXXXXXXXXXXXXXXXXX/winfx/2006/xaml/presentation" xmlns:x="XXXXXXXXXXXXXXXXXXXXXXXXXXXX/winfx/2006/xaml" x:Class="XXXXXXXXXXXXXge1" > <Button Click="HelloWorld" Name="Button1">Click Here
</Button> </Page>
接着使用 C# 建置
using System; using System.Windows; using XXXXXXXXXXXXXXXXXntrols; namespace XAMLSample
{ public partial class Page1
: Page
{ void HelloWorld
(object sender, RoutedEventArgs e
) { MessageBox
.Show("Hello, world!"); } } }
易语言
.版本 2
.程序集 窗口程序集1
.子程序 __启动窗口_创建完毕
信息框 (“Hello, World!”, 0, )
