stm32 的问题,usart 中断怎么进不去
azenis_xing2010/08/20电子技术 IP:陕西
我的stm32 中断为什么进不去,都弄了好几天了,郁闷啊!
望高手指教,代码如下:
#include <stm32f10x.h>
#include "stm32f10x_it.h"
void UART2_GPIO_Configuration(void);
void UART2_Configuration(void);
void NVIC_Configuration(void);
void delay(uint32_t nCount);
int main()
  SystemInit();
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
  NVIC_Configuration();
  UART2_GPIO_Configuration();
  UART2_Configuration();
  while(1)
  这里不停的发送那个变量的值,初始值为0,进入接受中断后更改其值
/*********************************配置UART2的GPIO口*************************************/
GPIO_InitTypeDef GPIO_InitStructure;
// Configure USART1_Tx as alternate function push-pull
GPIO_XXXXXXXXXXXXXXXXIO_Pin = GPIO_Pin_2;
GPIO_XXXXXXXXXXXXXXXXIO_Speed = GPIO_Speed_50MHz;
GPIO_XXXXXXXXXXXXXXXXIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
// Configure USART1_Rx as input floating
GPIO_XXXXXXXXXXXXXXXXIO_Pin = GPIO_Pin_3;
GPIO_XXXXXXXXXXXXXXXXIO_Mode = GPIO_Mode_IN_FLOATING;
//GPIO_PinRemapConfig(GPIO_Remap_USART2, ENABLE);  //复用重映射UART2
/************************************配置串口2参数***********************************/
   USART_InitTypeDef USART_InitStructure;
   USART_XXXXXXXXXXXXXXXXART_BaudRate = 115200;
   USART_XXXXXXXXXXXXXXXXART_WordLength = USART_WordLength_8b;
   USART_XXXXXXXXXXXXXXXXART_StopBits = USART_StopBits_1;
   USART_XXXXXXXXXXXXXXXXART_Parity = USART_Parity_No ;
   USART_XXXXXXXXXXXXXXXXART_HardwareFlowControl = USART_HardwareFlowControl_None;
   USART_XXXXXXXXXXXXXXXXART_Mode = USART_Mode_Rx | USART_Mode_Tx;
   USART_Init(USART2, &USART_InitStructure);
   USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);       //使能UART2接收中断
USART_Cmd(USART2, ENABLE);
* Function Name   : NVIC_Configuration
* Description        : Configures NVIC and Vector Table base location.
* Input                    : None
* Output                 : None
* Return                 : None
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Configure one bit for preemption priority */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
中断服务程序如下:
  if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET)
    /* Disable SC_USART RXNE Interrupt */
   在这里我通更改一个变量的值,然后再主函数里继续死循环的发送。
但是,一旦从电脑上通过串口发送个数据,就死掉了,是怎么回事啊!
azenis_xing 作者
14年6个月前 IP:未同步
250404
再补充一点,就是在中断里已经通过读取数据进行过清除中断标志了,用过了clearpending 了,望老手指教,怎么回事啊
jrcsh
14年6个月前 IP:未同步
250423
STM32  机械周期有多快
10班陈大葱22号
14年6个月前 IP:未同步
250456
不会用USART中断的路过...等warmonkey来吧
14年6个月前 IP:未同步
250521
lz最好用调试器看看死在哪里了,JLink很方便
首先确定进入了接收中断才行
azenis_xing作者
14年6个月前 IP:未同步
250535
继续问
现在不死了,可能先前是哪没连接好吧
现在的问题是进入不了接收中断,也就是在串口调试助手上看不到接收的数据,看了下配置,应该没问题啊,到底怎么回事啊?
14年6个月前 IP:未同步
251225
Re:继续问
引用第5楼azenis_xing于2010-08-20 18:54发表的 继续问 :
现在不死了,可能先前是哪没连接好吧
应该说错了吧。。。不能理解
另外中断标志位清零与否没有很大关系,中断响应完毕自动清零的
14年3个月前 IP:未同步
265050
先确认一下串口的好坏吧
luojihao217
13年3个月前 IP:未同步
339127
你是不是运行RAM里?要加NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
