哼,VB的速度也是很牛逼的,VB很萌的,乃们不要再黑VB了
dd2010/07/17软件综合 IP:广东
今天特别高兴特别蛋疼,于是把mean shift花了2小时移植到VB上[我知道大部分时间我都在debug]
Mean Shift 算法 在XXXXXT上跑,320 x 240,跟踪窗口30 x 30,CPU T6570,内存2G,Win7
实时跟踪绰绰有余
虽然在下一秒……
+500  科创币    小俊    2010/07/17 优秀
来自:计算机科学 / 软件综合
53
dd 作者
14年6个月前 IP:未同步
237039
放出代码
Public Class MeanShift
    Const HISTOGRAM_LENGTH As Integer = 4096
    Private imgWidth As Integer
    Private imgHeight As Integer
    Private trackWinWidth As Integer
    Private trackWinHeight As Integer
    Private currentX As Integer
    Private currentY As Integer
    Private currentHistogram(HISTOGRAM_LENGTH) As Double
    Private tempHistogram(HISTOGRAM_LENGTH) As Double
    Public Sub InitMeanShiftTracker(ByVal firstFrame() As Byte, ByVal frameWidth As Integer, ByVal frameHeight As Integer, _
                ByVal targetPosX As Integer, ByVal targetPosY As Integer, ByVal targetWidth As Integer, ByVal targetHeight As Integer)
        imgWidth = frameWidth
        imgHeight = frameHeight
        currentX = targetPosX
        currentY = targetPosY
        trackWinHeight = targetHeight
        trackWinWidth = targetWidth
    End Sub
    Public Function CalcHistogramSp(ByVal frame() As Byte, ByVal histogram() As Double) As Integer
        Dim pxValue As Integer = 0
        For i As Integer = 0 To HISTOGRAM_LENGTH
            histogram(i) = 0
        Next
        For j As Long = XXXXXXXx(0, currentY - trackWinHeight / 2) To Math.Min(currentY + trackWinHeight / 2, imgHeight - 1)
            For i As Integer = XXXXXXXx(0, currentX - trackWinWidth / 2) To Math.Min(currentX + trackWinWidth / 2, imgWidth - 1)
                Dim r As Integer = frame(j * imgWidth * 3 + i * 3) / 16
                Dim g As Integer = frame(j * imgWidth * 3 + i * 3 + 1) / 16
                Dim b As Integer = frame(j * imgWidth * 3 + i * 3 + 2) / 16
                histogram(Int(256 * r + 16 * g + b)) += 1
                pxValue += 1
            Next
        Next
            histogram(i) /= pxValue
        Next
        Return pxValue
    End Function
    Public Function MeanShiftProcessSp(ByVal frame() As Byte)
        Dim weights(HISTOGRAM_LENGTH) As Double
        Dim newX As Double = 0.0
        Dim newY As Double = 0.0
            If currentHistogram(i) > 0.0 Then
                weights(i) = tempHistogram(i) / currentHistogram(i)
            Else
                weights(i) = 0
            End If
        Next
        Dim sumOfWeights As Double = 0.0
                Dim ptr As Integer = 256 * r + 16 * g + b
                newX += weights(ptr) * i
                newY += weights(ptr) * j
                sumOfWeights += weights(ptr)
            Next
        Next
        If sumOfWeights <> 0 Then
            currentX = Int(newX / sumOfWeights) + 0.5
            currentY = Int(newY / sumOfWeights) + 0.5
        End If
        Return Nothing
    End Function
    Public Function MeanShiftTrackProcess(ByVal frame() As Byte, ByVal frameNumber As Integer)
        If frameNumber = 0 Then
            XXXXXlcHistogramSp(frame, tempHistogram)
        Else
            Dim stopThreshold As Integer = 10
            Dim counter As Integer = 0
            While counter < stopThreshold
                XXXXXlcHistogramSp(frame, currentHistogram)
                Me.MeanShiftProcessSp(frame)
                counter += 1
            End While
            Me.DrawTrackBox(frame)
        End If
        Return Nothing
    End Function
    Public Sub DrawTrackBox(ByVal frame() As Byte)
        For i As Integer = currentX To Math.Min(imgWidth, currentX + trackWinWidth)
            frame(currentY * imgWidth * 3 + i * 3 + 0) = 0
            frame(currentY * imgWidth * 3 + i * 3 + 1) = 0
            frame(currentY * imgWidth * 3 + i * 3 + 2) = 255
            frame(Math.Min(imgHeight - 1, currentY + trackWinHeight) * imgWidth * 3 + i * 3 + 0) = 0
            frame(Math.Min(imgHeight - 1, currentY + trackWinHeight) * imgWidth * 3 + i * 3 + 1) = 0
            frame(Math.Min(imgHeight - 1, currentY + trackWinHeight) * imgWidth * 3 + i * 3 + 2) = 255
        Next
        For j As Integer = currentY To Math.Min(imgHeight - 1, currentY + trackWinHeight)
            frame(j * imgWidth * 3 + currentX * 3 + 0) = 0
            frame(j * imgWidth * 3 + currentX * 3 + 1) = 0
            frame(j * imgWidth * 3 + currentX * 3 + 2) = 255
            frame(j * imgWidth * 3 + Math.Min(imgWidth - 1, currentX + trackWinWidth) * 3 + 0) = 0
            frame(j * imgWidth * 3 + Math.Min(imgWidth - 1, currentX + trackWinWidth) * 3 + 1) = 0
            frame(j * imgWidth * 3 + Math.Min(imgWidth - 1, currentX + trackWinWidth) * 3 + 2) = 255
        Next
    End Sub
End Class
ltl
14年6个月前 IP:未同步
237045
VB就是渣!!!
dd作者
14年6个月前 IP:未同步
237049
引用第2楼ltl于2010-07-17 22:13发表的  :
VB就是渣!!!
欢迎来晒下限
嘛  反正mean shift算法我cpp  Delphi  vb三个版本都写过了,我有姿势我自嚎
startwood
14年6个月前 IP:未同步
237070
纯属无聊,往VB上移…………
不过VB在做小东西方面还是可以的,比CPP方便。
insaneform
14年6个月前 IP:未同步
237073
顶楼主!debug的滋味就好象……
不懂VB的飘过……
blackiller
14年6个月前 IP:未同步
237075
问一下,mean shift 算法是什么呀,高手指教一下
noname剑人
14年6个月前 IP:未同步
237080
啥时候给移植到ASM上……
那个就崩了……
我到现在图像的API还没用过几个……
小俊
14年6个月前 IP:未同步
237088
话说大家写这类算法的时候好像都不习惯用多线程。。。那样大家的双核四核CPU实在是浪费了。。。
把这个代码改成多线程,说不定就把93那个CPP版给秒了。
caoyuan9642
14年6个月前 IP:未同步
237092
还是觉得VB垃圾。。。
与其用VB不如学VC了。。。
最忍受不了的就是VB全局和局部变量Ms不能相同。。。
startwood
14年6个月前 IP:未同步
237107
引用第8楼小俊于2010-07-17 22:45发表的  :
估计不行吧,T6570只有2Core,VB的效率不到CPP一半。LZ之所以得出VB牛的观点,是因为硬件够强。在Pentium M 1.6GHZ上可能CPP版的还能实时,VB版的就不行了。不信LZ把CPU调到1.6GHZ或更低看看。
小俊
14年6个月前 IP:未同步
237110
引用第10楼startwood于2010-07-17 22:55发表的  :
上i7,多核+超线程
dd作者
14年6个月前 IP:未同步
237125
那啥,我就是93
还有那啥,php天空中国 貌似乃上次折腾个取色都
14年6个月前 IP:未同步
239849
93能不能准确测量一下执行时间?可以做个参考比较
phpskycn
14年6个月前 IP:未同步
239859
取色没啥问题,问题在疼讯的那啥防外挂的东西,把它干掉游戏进不了,让他干不掉还是进不了。
orichalcum
14年6个月前 IP:未同步
241956
VB6渣不代表XXXXXT渣,说后者渣几乎就是在说.net渣了吧
epi.clyce
14年6个月前 IP:未同步
241998
偷换概念
.NET Frame Work下啥都一样
你拿VB6试试 = =
phpskycn
14年6个月前 IP:未同步
242048
.net绝对渣
很多东西是不能要拖那么大个运行库的。。。
orichalcum
14年6个月前 IP:未同步
242100
引用第17楼phpskycn于2010-07-28 15:23发表的  :
.net绝对渣
是啊,楼主这东西是就应该单独弄个单片机来做,拖个那么大的Win7干什么。
.NET现在还有多少需要装的?
93°
14年6个月前 IP:未同步
242104
引用第16楼clyce于2010-07-28 12:44发表的  :
偷换概念
你拿VB6试试 = =
VB6不比XXXXXT慢,
啥都一样 要不要我用C#来一发指针试试?
.net绝对渣
下限帝自重啊,你知道java运行库多大不?现在还有人敢喷运行库?
在喷之前敢把自己的程序写好么?
绝对渣?敢到csdn上喷么?你知道XXXXXXt跑起来的速度跟php差不多甚至性能还要好一点么?你知道在对象使用,类库调用上,XXXXXXt的性能都远高于PHP吗?你知道除了文件复制操作之外,XXXXXXT在性能方面全面领先于PHP吗?
cwood
14年2个月前 IP:未同步
265985
回 10楼(startwood) 的帖子
何以见得?VB的速度是CPP的一半?
这人真是........
cwood
14年2个月前 IP:未同步
265986
回 6楼(blackiller) 的帖子
一种人脸跟踪算法
cwood
14年2个月前 IP:未同步
265987
回 1楼(dd) 的帖子
这代码还可以再优化
cwood
14年2个月前 IP:未同步
265988
回 9楼(caoyuan9642) 的帖子
你懂VB么?你懂VB么?你懂VB么?你懂VB么?你懂VB么?你懂VB么?你懂VB么?
krfantasy
14年2个月前 IP:未同步
266042
vb编这些可以拿来测试CPU的运算速度。。。
krfantasy
14年2个月前 IP:未同步
266043
Re:回 10楼(startwood) 的帖子
引用第20楼cwood于2010-11-18 13:19发表的 回 10楼(startwood) 的帖子 :
何以见得?VB的速度是CPP的一半?
这人真是........
平常大概在CPP的1/10的样子。。。
krfantasy
14年2个月前 IP:未同步
266044
引用第19楼93°于2010-07-28 18:02发表的  :
在喷之前敢把自己的程序写好么?
反正VB和ASP都是垃圾,整体性能老化,这些都只适合小项目。
krfantasy
14年2个月前 IP:未同步
266045
回 23楼(cwood) 的帖子
我懂,但是说实话VB适合学习,不适合项目
supercat
14年2个月前 IP:未同步
266058
嘛....用纯C的路过......用pthread乃至GLib写多线程程序还是很容易的~~~~
cjboy2008
14年2个月前 IP:未同步
267758
引用第28楼supercat于2010-11-18 22:32发表的  :
我倒是没有直接用过pthread和GLib,都是用Qt封装的类。
yangff
13年4个月前 IP:未同步
322677
VB运行效率确实渣这个没必要比较了,
VB、Basic、XXXXXT麻烦大家分清楚了再来说这三个家伙除了语法差不多以外根本不一样
婺源寻芳
13年4个月前 IP:未同步
323372
vb的速度不是問題。會寫的人可以加速到c的水平。
語法比較古董一些而已。
riabox
13年4个月前 IP:未同步
323423
这东西真不是vb,是.net,XXXXXt != vb
dd作者
13年4个月前 IP:未同步
323424
谁能帮我把这贴删掉。。。 = -
x_uy_u_n
13年4个月前 IP:未同步
323426
为什么要删帖?算法才是关键吧,VB什么的都是工具.
wacke
13年4个月前 IP:未同步
323439
把运行时间和配置都会抓出来比比不就有结果了。我相信cpp肯定可以比vb快。
wacke
13年4个月前 IP:未同步
323442
有兴趣的可以比比谁能优化的更快。再封装成库。这会有点作用。
dd作者
13年4个月前 IP:未同步
323461
各位少侠请放过我吧。。。。我已经金盆洗手不干了 。。。我再也不敢了 Orz 我错了我不会写程序我是2B
x_uy_u_n
13年4个月前 IP:未同步
323665
[s:275]楼主不要这样,我觉得你很厉害.不要因为别人说什么而否定自己.
潜水员
2011-09-23
你不懂楼主在卖萌我就不扣你分了。。。。
ok520
13年3个月前 IP:未同步
331901
是的.楼主很强
shoiv
13年3个月前 IP:未同步
332362
celeron533
13年3个月前 IP:未同步
332453
vb虽然渣,但是开发小项目的速度很快
电脑忙一点,人轻松了
mewlex222
13年3个月前 IP:未同步
332702
哈哈   很好啊  可是还是喜欢cpp
自在的尘
13年2个月前 IP:未同步
336000
VB,VC,.Net,JAVA,C,各有所长,用的时候各取所需罢了
没必要否定哪个。
要性能的用C,要开发效率的用.net ,JAVA,简单易用就VB。
LiuNianqiu
13年2个月前 IP:未同步
337304
楼主的研究很有意义啊,至少说明目前的配置VB也能做人脸,毕竟产生价值的是最后的产品,语言只是工具而已,就像普通螺丝刀和电动螺丝刀,都不过是扭扭螺丝罢了
婺源寻芳
13年2个月前 IP:未同步
337600
vb的问题并不在速度。而在语法。
比尔盖茨原先就是做basic的。操作系统是他花五万美元买来的。
所以basic 是比尔盖茨的初恋情人,也导致微软被这语言绑住。
csakura
13年1个月前 IP:未同步
343405
在喷之前敢把自己的程序写好么?
CSDN远不如多年前的,就剩下几个完全为了拯救CSDN而存在的回答专家。
回答质量远不如SO,社区凝聚度远不如iteye等。
对于java、还是.net很难一概而论,java和.net都可以移植到arm7这类只有几百K内存、主频只有几十M的CPU上进行裸奔。
而VB确实是个过时的东西,XXXXXT和VB不是同一个东西。对于语言来说,光调调系统接口,直接访问下内存没多大的意义。
现在的语言发展是如何快速解决软件工程上的问题,所以新语言都拥有很多快速开发的新特性,例如:闭包、函数式编程、模块、自省等等。
矩阵员
11年6个月前 IP:未同步
548696
楼主你好:我觉得你在编程方面有一定的功力了,你发表这贴子,可能只是闲暇之余好玩的,我也用过VB,觉得还可以。VB只是工具而已,和C# C++ JAVA一样仅仅是工具,要怎样用还是要看使用的人,这个VB是微软的起家产品!VB刚出来时不知道楼上说VB是渣的人在干什么! 51单片机问世要几十年了吧!可还有人在用,不是它慢,而是它可以用,更说明设计51的人和思想是多么的经典,所以不能以以速度快慢来衡量VB,而是你了解VB多少!我想说那些说“VB是渣”的人,你运的运算速度比VB如何,难道。。。。。。。
相对论万岁
2013-07-16
坟贴看看就好,不要挖了!
流星街
11年6个月前 IP:未同步
548817
楼主我不是很熟悉编程,但是知道VB的程序对支持库的依赖很严重,自己写程序自己用还好,发给其他人就往往运行时缺少某必要的XX库而出错,并且好像极其容易在网络操作一块出现各种错误(不知道是编程者对VB不够精通还是VB本身有些缺陷),另外看到很多大牛都喷VB说这是微软想要垄断整个软件行业而提供了大量封装好的库和API来简便操作吸引程序设计者成为一种基础编程软件(表述好像有问题)。。。。不过都去ASM似乎也不现实,不过现在不少软件采取多种混合,C的驱动,D的界面,VB的DLL。。。。各有优势,看什么人用以及用在什么地方吧,,,我这个水平的也就是玩玩易语言糊弄小孩子,不过真心感觉易语言跟C++像。。。。
celeron533
11年6个月前 IP:未同步
548873
回 48楼(流星街) 的帖子
.Net以后,装完framework就直接跑
易语言真的死掉了,官网已经很久没更新
phpskycn
11年6个月前 IP:未同步
548875
回 48楼(流星街) 的帖子
VB6可以直接编译,不需要RTL了,而且VB6也是最后一个不需要.net的版本……
dd
2006/10/31注册,6年11个月前活动
