KC客户端另一版本公布
helium2013/04/21软件综合 IP:湖南
这个是我在rexsee网站在线做的一个客户端,由于还没学会编程,我暂时没办法编辑改进。
欢迎懂编程的同学可以把改进方案发上来,以便在线编辑调优。
起始原软件看帖功能很强大,视频图片都能直接看,电脑网页界面显示,可以评KCB...............只是有些Bug:签不了任务拿KCB、不能直接发贴。
起始原软件:
attachment icon com.rexsee.website.w1360836561-release.apk 515.94KB APK 35次下载
另一稍改进版软件,改进了一些网页配置,但不知效果如何:
attachment icon com.rexsee.online.kechuang_apk_V1.a0-release.apk 668.62KB APK 52次下载
在线页面:
原软件在线编辑原代码(javascript脚本,可以在浏览器上在线编辑
编辑文件【/2013-02-14/XXXXXXxsee.website.w1360836561/assets/config.js】
var packageName="XXXXXXxsee.website.w1360836561";
var versionCode=1;
var versionName="1.0";
var websiteName="科创";
var websiteIntro="KC-手机";
var websiteHome="XXXXXXXXXXXXXXXXXXXXXXX/XXXXXXXXp";
var websiteIcon="XXXXXXXXXXXXXXXXXXXX/websitecache/2013-02-14/XXXXXXxsee.website.w1360836561/res/drawable-hdpi/XXXXXXXg";
编辑文件【/2013-02-14/XXXXXXxsee.website.w1360836561/assets/XXXXXXXXml】
<HTML>
<HEAD>
    <META http-equiv=Content-Type content=text/html charset=GB2312>
    <META http-equiv=Expires content=0>
    <META http-equiv=Cache-Control content=no-cache>
    <META http-equiv=Pragma content=no-cache>
    <SCRIPT type=text/javascript src="config.js"></SCRIPT>
    <SCRIPT type=text/javascript>
        var jsUrl = "XXXXXXXXXXXXXXXXXXXXX/website/ajax/XXXXXXXXXXp";
        window.onRexseeReady = function(){
            XXXXXXXXXXXXXXXXXeate('cover','LinearLayout','orientation:y;background-color:#000000;');
            XXXXXXXXXXXXXXXXXeate('progress','[s:9]rogressBar','mode:circular;width:36;height:36;');
            XXXXXXXXXXXXXXXXXtChilds('cover','progress');
            XXXXXXXXXXXXXXXXd('cover','border-width:0;bar-position:layout;');
            XXXXXXXXXXXXXXXXtAllowErrorDialog(false);
            rexseeAjax.submitWithCallback(jsUrl,"version="+versionCode,"GB2312");
        window.onAjaxReturned = function(ajaxUrl,response){
            response = unescape(response);
            eval(response);
            XXXXXXXXXXXXXXXXXtStyle("visibility:visible;");
            XXXXXXXXXXXXXXXXXXtStyle("visibility:visible;");
            XXXXXXXXXXXXXXXXXXXXXtStyle("background-color:transparent;");
            XXXXXXXXXXXXXXXXXXXXXtStyle("background-color:#FFFFFF;");
            XXXXXXXXXXXXXXXXXXd('init','XXXXXXXXXXXXXXXXearHistory();XXXXXXXXXXXXXXXXXXmove();XXXXXXXXXXXXXXXXmoveAll();XXXXXXXXXXXXXXXXXstroyAll();');
            rexseeBrowser.load(websiteHome);
        window.onException = function(className, message){
            //alert(className+":"+message);
            alert("嗨,看起来网络不太好,呆会儿再试吧。");
            rexseeApplication.exit();
        window.onAjaxTimeout = function(ajaxUrl,timeout){
        function copyright(){
            alert("本网站客户端由开发者自行使用Rexsee网站客户端平台创建,Rexsee网站客户端平台仅提供自动创建Android网站客户端的技术,不对作品版权、内容及质量负责,如有任何问题,请联络开发者,Rexsee不承担相关责任。");
    </SCRIPT>
<HEAD>
<BODY style="background-color:black;"></BODY>
</HTML>
+100  科创币    qg2010    2013/04/21 高质量发帖
+69  科创币    玄明    2013/04/21 辛苦了,把我脑袋搞得那么大
+25  科创币    powder    2013/04/29
来自:计算机科学 / 软件综合
helium 作者
11年9个月前 IP:未同步
518360
@虎哥
最高主机泡泡
2013-04-21
竟然有了@功能、、
acmilan
11年9个月前 IP:未同步
518374
个人认为,如果觉得不好可以替换,便于管理,也保证安全,最好不要搞多个版本
最要避免老死不相往来的情况[s:275]
20!Dopaminor
11年9个月前 IP:未同步
518442
回 1楼(能材爱好者) 的帖子
@能材爱好者   有消息提示么
@baiwenglong 被骗了....
qg2010
11年9个月前 IP:未同步
518466
@20!不曾存在 有没有?
11年8个月前 IP:未同步
519732
吐槽一下,现有客户端图片永远裂,根本无法打开图片,回复时经常出现输入窗口不断闪烁,还有许多问题一言难尽,期待更好的客户端
helium作者
11年6个月前 IP:未同步
539880
我公布的APP软件初步评测:【高级模式发帖回复,发出售帖回复,KCB评分,点击头像、ID、设置按钮弹出栏】
+25
powder
2013-06-24
高质量发帖
phpskycn
11年6个月前 IP:未同步
541418
这个和直接用Chrome for Android 有何区别呢
科学狂人1996
11年4个月前 IP:未同步
643809
无法解码,,,
helium
进士 学者 机友 笔友
2010/07/16注册,1天2时前活动
茂名佬~
