烤箱……
建议先直接浇注好一批发动机,然后防潮保存。即使不出危险,这样烘来烘去的也会影响燃烧。
引用第2楼mawenhao于2010-08-01 00:03发表的 :
Step 2: Molding the grains
A bit of propellant has been heating in the toaster-oven at 200 degrees. After 20 minutes or so, it is nicely soft..
DO NOT HEAT PROPELLANT IN A MICROWAVE OVEN! It will ignite!
The propellant is recrystallized KN/sucrose to which 1 percent red iron oxide (Fe2O3) has been added. This gives it a brick-red color, and increases its burn rate. Kn/dextrose works too, and does too, although it burns with a little less enthusiasm.
A small chunk of propellant is cut off, rolled into a slug, and pressed into the longer molding tube with a short stick. A little more may be added while it is still hot. The tube is filled to within about 1/8 inch of the top, and pressed down firmly.
